Una duda sobre el refrigerante.
yamarossi46
Post by yamarossi46 »
Saludos, a todos. Bueno la cuestión es que mi FZR 600 GEN. 92, después de dos años parada, he decidido volverla a usar y al quitar el tapón de llenado del líquido que refrigera el motor, éste, se desborda por la boca. :headscratch: ¿A qué puede ser debido?. La moto fue arrancada en su día y el refrigerante puesto nuevo. Como siempre gracias y cuidarse fuera.
Greetings, all. Well the issue is that my FZR 600 gene. 92, after two years of no use, I have decided to return it to use and removed the coolant cap, it overflows through the mouth. What may be causing?. The motorbike was started(pulled up) in due time and the refrigerant made new. As always thanks and be careful outside.
(That's as good as the Google translator could do - rage)
SouthendChris
Level 2.0
Level 2.0
Re: Una duda sobre el refrigerante.
Post by SouthendChris »
From what I ca gather. Your FZR600 Genesis has been laid up for 2 years. You have just started using it again.
You are having Coolant / Antifreeze come out of an overflow pipe???
Run the bike with the Coolant cap off for about 3 or 4 minutes, rev it upto 5000rpm a few times, this may help purge any air bubbles in the system.
It may also be that your thermostat has decided to seize shut as it hasn't opened in so long???
I hope you get it sorted.
Chris
1990 3LN3 FZR250 - back in safe hands :)
3x RG80 Gamma :)
yamarossi46
Muchas gracias Chris, yo pensaba algo de esto, de burbujas de aire, pero no tengo experiencia en este motor. Saludos.
