Swapping out (reversing) your clip-ons
vmaxmike
Post by vmaxmike »
anyone ever tried this? That is...removing the left side clip-on, flipping it over and installing on the right side and vice versa....so the angle would then be bent slightly up rather than down.(you'd have to drill new dowel pin holes of course) The idea being raising slightly the riding position towards a more standard style? Would this interfere with the windscreen cage maybe?
Or...anyone ever do the Seca II handle bar / upper clamp swap?
blensen
Level 2.5
Level 2.5
Re: Swapping out (reversing) your clip-ons
Post by blensen »
I did it with my naked FZR. It was definitely more upright and easier on my wrists. It actually convinced me to go the full bars & risers route.
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
DonTZ125
Moderator
Post by DonTZ125 »
You actually don't need the dowel pins so long as the clamping screws are properly torqued. I would suggest the dowels are a lawyer-riffic addition to prevent stupid owners from hurting themselves when they do work on the bike and don't torque the bolts properly.
Or, from a spate of stupidity from a few years ago, when bikes came from the factory with loose clipons and weren't properly assembled by the dealership ...
vmaxmike
Post by vmaxmike »
yeah, i figured torquing the bolts adequately should suffice. My only concern is on full turn (like maneuvering out of tight spot/backing up) the clip or my hand might hit against the screen cage. I'll just have to try it and see...Image
Dlamb
Post by Dlamb »
I was wondering the same with the clips. Have you done it yet? Did it work?
