HID head light
HID head light
I tryed searching this topic before i posted it but couldn't find anything realy. I just got my bike up and running great and decided for the first time i would take a night run with it. Problem is i cant see isht in front of me even with the high beam. Has anyone wired an HID kit and if so which one did you guys use?
Re: HID head light
Search "HID" gets 187 hits here, some of which will be from "hid as in hidden " but....................
Re: HID head light
like i said i did use the search and all post with "HID hidden" just talk about when there selling the bike that has HID or talk about newer yzf or r6's. I have a 92 which is a single headlight and was wondering how they wired up the bulb considering there is a boot cover over the light and the connector is a 3 pin instead of like the newer ones where its like a socket.
Re: HID head light
I found my answer actually on youtube which is another great resource
...........In order to make the HID kit work to your factory headlight connector, you have to put ends on the end of the HID wire and input each wire into your factory headlight connector.
http://www.youtube.com/watch?v=tUWLz8ddMrk
Re: HID head light
Hmm not a problem that I came across as my kit came with the right three pin connector to plug into the original bulb socket so the original harness acted as the switch from lo beam to hi beam.
My kit was "Super Vision F1 Sport Racing" from China
