bike stopped need help
today my bike stopped fzr 600 i could smell somthing before it stopped . i took seat off and found the battery was swollen ,dry cell. wen i got it home i found the fuel pump was at a dead short and i checked for spark but no go, i have replaced the blown fuses wich were the main 30 amp and the 10 amp under seat the coils have power on all the wires is this right or have i also fried the ignighter . any ideas ?
- kilika2
- 1000+ Posts
Re: bike stopped need help
Yep I bet your VR took a dump on you. I have a feeling it was overcharging and booked your battery dry then started down the line. Are you bulbs still in tact? Does your bike have the pre 95 "candy bar" style VR? Your ignitor might be gone too.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
thanks bro i pryed igniter open to find it cooked any ideas how to fix or to find another also would you know if i could hard wire a low pressure fuel pump up on a sep switch about 6psi max would this work
- kilika2
- 1000+ Posts
There is a guy on the forum called DonTZ125. He does TCI repair and everything. Search him out for the electrical stuff it's out of my league now. Sorry.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
Kilika - Thanks for the kind words!
Cam - can you post some pics of the ignitor? I can fix some things, but a sufficiently fried TCI is just that - fried. The TCI should control the stock fuel pump through the main relay assembly, unless the relay is also dead. 6psi is a little high; you only need 2 or 3. Any bike carb fuel pump will do the job. Is it the pump or the relay that's "at a a dead short"?
If you are going to keep this bike, the first thing to do is get rid of that VRR. Replacing anything else at this point is a fool's errand, since the VRR will just kill it again. If you have the old 4-pin VRR, you should upgrade to the newer 5-pin design. Shameless advert - I sell an adaptor to make this a near plug'n'play experience.
hi bro cheers for the reply i finaly sent them off to a company in south australia called betta bikes look em up they are great . They have a change over electrical shop
