Amongst the long list of things that the bloke who sold it didn't tell me about....
is that, at slow speeds when decelerating (say as you go into second gear for a slowish corner..) using the resistance of the engine to smoothly slow the bike, mine doesn't!!
It will lurch and catch, lurch and catch a bit... which does amazing things for your balance...
At higher speeds on engine braking it is fine...
I've also noticed that the clutch, with the lever fully adjusted outward, (I dont have it like that tho, I have it looser at the lever because i want the biting point to be closer to the grip for comfort (not sure this is the best way)..) ...is very, very heavy.
Under use, the clutch feels a bit grabby, all or nothing, a bit...and occasionally has a little bit of a slip for a second as you pull away..
It almost seems like something is adjusted too tight hence lower speed engine braking becomes jerky not smooth..????
Where should I start chaps..??
The other issue (although not overwhelming) is that the first quarter of the throttle feels like its underpowered and then the bike is quick..
i expected it to be nippy from the get go, but you need to get and keep the revs up a little for the performance??
there is a rather nice sounding aftermarket can made by ART Pro Series II
fitted to the bike...
I did ask a yammy tech and he said that the lack of power may be a fueling issue and that the carbs probably hadn't been jetted for the end can...
he suggested adjusting the needle height on the carbs one stage higher to increase the rate of initial fuel flow presumably??
The engine does rev in the first quarter throttle but it's not directly translated into what you would expect the power to feel like at the back wheel...
Could it be clutch related also i wonder... I would of thought if there was any clutch slip it would be at the higher rev range..
bear in mind i just sold my fzr1000 exup and that was nippy from the start line..
Any wisdom, would be absolutely norman.
Cheers.
