Sprocket Kit
Re: Sprocket Kit
DonTZ125 wrote:Specific power isn't terribly meaningful when discussing chains. My TZ puts out over 300 RWHP per litre - but that's still only 38 hp... :grinnod:
Don,
you had to spoil it :-} the idea was to re-assure that clip chains are safe if done properly.
yamaboy
Level 1.5
Level 1.5
Re: Sprocket Kit
Post by yamaboy »
kilika2 wrote:As far as sprocket size I went -1/+2 and love it. Lost maybe 6mpg but I can whoop my buddy's 02r6. Just saying.
Cool . Not to beat the horse but I hear hard launches on the FZR will ruin the weak transmission. What do you guys think about that? Is it quicker throughout gears? I don't care much about top speed; Twisties is what it's all about !
I ended up ordering 14/47(PTFE) Vortex sprockets and a 520XSO-106 chain. This sucks..nice weather and my bike is apart ..I guess I'll just :drink:
1995 ,FZR 600,Factory Pro 1.1Ti Jet Kit, Yoshi slipon,K&N filter,elevation 4200 ft above sea level.
Carb settings: Main Jet 110, Starter Jet 52.5,Needle @ 3rd position,23m Floats,about 3 turns IM Screws.
80's-90's,Rap..music.?? http://www.last.fm/listen/user/unsmenar/personal
DonTZ125
Moderator
Re: Sprocket Kit
Post by DonTZ125 »
The weak point on the FZR transmission (and many bikes, actually) is the 1-2 jump, leaving 2nd pretty messed up. Some who do a lot of hard pulls through the gears start off in 2nd.
apsolus
Level 2.5
Level 2.5
Re: Sprocket Kit
Post by apsolus »
any idea why 1-2 is the weak piont? is it because of nuetral?
DonTZ125
Moderator
Re: Sprocket Kit
Post by DonTZ125 »
Yup. If you don't get it just right (don't load the shifter hard enough, the pedal is mis-adjusted, you mis-time the gas), the odds are REALLY good you'll blow the shift, and it'll jump out of gear into neutral. Now, any half-assed shift can find a false-neutral, but with REAL neutral sitting right there it's a lot easier.
Doesn't take too many blown shifts to start chewing away at your shift drum and dogs...
cntryboy85
Level 3.0
Level 3.0
Re: Sprocket Kit
Post by cntryboy85 »
sorry about reviving an old post...but got a question. doing the 660 build and looking at new chain and sprockets. what is a good combo to go with for the build. not looking for top speed i have no need to do 140+mph it already does that at factory but would love a little more off the line or when trying to get up in traffic.
pefrey
Level 5.5
Level 5.5
Re: Sprocket Kit
Post by pefrey »
Small front, large rear gets you the fastest acceleration. 15/50 seems pretty well available, maybe even 14/50.
cntryboy85
Level 3.0
Level 3.0
Re: Sprocket Kit
thanks for the info i will keep that in mind
