Ok so last night I finished stripping the rims and dealing with that.
Tonights focus was to figure out why my front suspension feels like a ninja 250.
So, after reading numerous posts and topics about how to fix this, I decided to start cheap (can allways upgrade later with racetech or something of that nature). So I got ahold of some 20 weight oil and swapped that in the front forks, drained 13 oz out and replaced with 13 oz of fresh. Keep in mind I did all this with the forks still on so I definitly did not drain all the old oil. Not worried about it, again...these are my starter forks
Ok then I wanted to deal with the issue of the nose dive and saggy front, I I went to LOWES and picked up the closest sized PCV pipe to replace the stock 1 1/4 inch diameter spacer. After cutting and grinding flush the new pvc spacers I put them in. They were slightly more than a 1/2 inch longer than the stock spacers. By the way putting the caps back on was a test of patience. Having to compress the now more resistant springs and twist the caps was tough...Ended up rigging a set up involving a 1/2 in socket over top the 3/8 socket (can give more specifics if anyone is trying this).
End result of the (cheaply) upgraded front is great. I was launching in first and nailing the front and it did not bottom out and felt pretty good. Not nearly as stiff as my 08 ZX6R was but that is good...hopefully more comfortable for distance trips.
I also cut out a circle of tape to place over the ram air tube inlet. Installed rear red LED (awaiting clear tail light lens). Removed old windscreen (awaiting new one).
Ok so overall bike came with:
stainless steel brake lines (front)
d@d exhaust
jet kit
I have completed/added(or ordered and awaiting):
stripped rims and inside painted black
flush mounted turn signals
larger spacers and thicker oil in front suspension
new clear windscreen
clear tail light with led bulbs
then a bunch of tweaking/fixing of stock parts (mostly replacing missing bolts)
Bought for 1000. I am sitting at 1160 invested total.
