Hi, first post is a question.
I ordered these onlne (these are the size tires currently on the bike) but the CS rep called me and said they were out of the 150/60 and suggested the 170/60. Now I looked at the stock tire sizes on FZR Archives and they are even smaller than what i have on thr bike.
Will the 170/60 cause problems on the rear? I read a YZF forum where they were going up to a 180 size tire for the rear. But I'm not sure if the rim is the same for the FZR vs YZF.
Yam93 pointed me to this forum. I am also a member at FZR archives.
TiresBridgestone Battlax BT014 Tires - Z-Rated - Rear
150/60-18 Z-Rated (BR-014-15/6Z18)
Bridgestone Battlax BT-021 Sport Touring Tires - Z-Rated - Front
120/70-17 Z-Rated (BR-021-12/7Z17)
Tire size and Hello
Re: Tire size and Hello
Ok I feel like a schmuck ( I looked at the sticker on the tire
)it is actually 160/60 so they should be fine.
demon_knight69
- Level 4.5
generally speaking 150/60 is the largest that is recommended, but a few guys on the forums have had no issues with a 160/60. so you should be ok.
1996 FZR 600
K&N Pods
Barnett Clutch
Factory Pro shift kit
K&N Pods
Barnett Clutch
demon_knight69 wrote:generally speaking 150/60 is the largest that is recommended, but a few guys on the forums have had no issues with a 160/60. so you should be ok.
If its being mounted on the FZR you will have to space out your brake arm I believe.
It will rub on your brake arm. I've seen people who have had to shave down the tire to make it fit. I would suggest sticking with nothing larger than a 150 which fits very nicely.
- abs929cbrrr
- 1000+ Posts
if you want a 160 you should mod your breake arm a little...if you want larger do wheel swaps.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
