When is it time to adjust your valves?
jax
Level 2.0
Level 2.0
Post by jax »
Hi all,
My bike is going on about maybe 12K since the last adjustment. I am having to give it alot of choke to get it started when its cold. Runs like crap until warmed but once warmed runs good. is this a sign that I need to check my valve clearances and possibly do a adjustment?
haunter
Re: When is it time to adjust your valves?
Post by haunter »
Could be, the service interval is like 24K miles, but that doesnt mean it wont need it early
jax
Level 2.0
Level 2.0
Post by jax »
Right on. I'm going to go ahead and take some measurements to see if they are out of spec. I'll report back with my numbers. Thanks.
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
How many total miles are on your motor?
jax
Level 2.0
Level 2.0
Post by jax »
ragedigital wrote:How many total miles are on your motor?
Total miles is right at 65K
Engine got new rings and new valve stem seals and valve lapping at about 55K...........due to a stripped spark plug hole.
haunter
Post by haunter »
that would have been a great time to adjust the valve clearances :-p
jax
Level 2.0
Level 2.0
Post by jax »
They were checked and found in spec at that time. I also wrote down all the shim numbers so I can have them for reference for next valve adjustment.
haunter
Post by haunter »
I wouldnt worry about them, and would think maybe you need to adjust the idle circuit screws
sorry I reasked what you had said and I had replied too....dur durr dur
jax
Level 2.0
Level 2.0
Post by jax »
Yeah. Just for peace sakes I am going to measure them again. if all is within spec then I know I need to mess with the carb setting and maybe get a sync done.
