THROTtLE CABLES
haunter
Re: THROTtLE CABLES
Post by haunter »
on your carbs is it the lower of the two?
does it go to YOUR side on the right control(instead of the front of bike side)
if so then that should be the push cable I think
PIMPMYFZR
Re: THROTtLE CABLES
Post by PIMPMYFZR »
FINALLY my throttle cable had ARRIVED . My 1st question is. Has anyone ever changed this or had to ? 2ND , Can i install this without taking off my Carbs and Gastank ?? and if so somone please fill me in !!!!!! :tks:
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
M in KC
Level 2.0
Level 2.0
Re: THROTtLE CABLES
Post by M in KC »
Easy peasie, Japaneesie. You will need to take your tank cover and air box off but you should be able to leave your gas tank on as IRC and you shouldn't have to remove your carb bank. Just make sure to route the new cable how the old one was, that is assuming the old one was routed correctly. And adjust the cable as appropriate. Toughest part will be working the carb cable end into the retainer thingie.
