I just got a set of ninja mirrors on ebay and they are so much better than the stockers
I had to lift my arm and lean to see with the mouse ears
The stalks are at least 2 times as long and the mirror itself is way wider
Totally worth the $20
best mirrors ?
Re: best mirrors ?
1994 Yamaha FZR600
- tampaFZR600
- Level 4.0
Re: best mirrors ?
this post is still going???? i got the YZF emgo mirrors...best ever
Re: best mirrors ?
anyone live in NY know if integrated mirrors are illegal? i was told by this one kid they were but have seen them on various occasions on other bikes around the area.
Re: best mirrors ?
Why then does Yamaha show a distinct different part number for the 89-90,93-99's and the 91-92's? I want to believe they're identical so that I can just buy any old mirror stay.. but are you sure?sweekster wrote:The mirror stays are the same between the dual and single head light 600s. It's the fairing stay that sets them apart.
Re: best mirrors ?
I'm quite sure of this. The mirror stay is exactly the same. Yamaha's numbering system can be, in some cases, "special". The part numbers in question are STAY, MIRROR 1duckling wrote: Why then does Yamaha show a distinct different part number for the 89-90,93-99's and the 91-92's? I want to believe they're identical so that I can just buy any old mirror stay.. but are you sure?
3HE-2831W-50-00 (91 FZR 600) & STAY, MIRROR 1 3HE-2831W-00-00 (96 FZR 600). As you can see they aren't that far off. My guess is they do this to differentiate the bikes from one another. You'd be surprised how many of the same parts have different part numbers.
Re: best mirrors ?
They are not the same. The 91-92 is for the single headlight model. It uses different mounting points for a few items. Partially because the fairing has a much more pronounced angle to it compared to the 89-90 & 93-99. You can use it, but it is not an exact fit and will require some minor modification to the light mounting tabs to work.
