New to the biking world etc . Me clutch on me fzr600 R is kinda lurching.
Eg: cruse at 5mph ..then it suddenly lurches then goes back to steady
cruse .
Only just got bike ...and know nothing about it . I was told that the
clutch was seized...taken apart /serviced then put back togther.
Plus how do i find out the exact model number (no log book yet...on
it`s way ). I know it`s a 600r but thats about it . It was a import.
Vin number 4JH-003046 if that helps
Any info greatly appreciated
nigi-baby.
dodgy clutch
- shredex
- 2000+ Posts
Re: dodgy clutch
cruze at 5mph??
when cruising at low idle, the bike will do that because its hard for it to pull a load on RPMs
give it more throttle!
Re: dodgy clutch
Lol !
Erm ..yeah i been running bike up and down a small street where me bike is
kept . It`s not on the road yet . So just been kinda testing it . Wots wrong
wi crusing at 5mph Lol . That way i get to choose the bugs i eat and spit
the ones out i don`t like Lol
Thanks for info bud
Nigi-Baby
Thanks for info bud
Nigi-Baby
Re: dodgy clutch
like shred said, if you dont give it enough gas you're gonna get that lurch. Same thing in manual cars if you ever see someone bouncing away from a stop sign.
Upgrades:
Re: dodgy clutch
4JH is a YZF 600 in the states.
Do YOU Scopper?
