A) charge it up on a low amperage charger (2amp or less) overnight. (make sure the battery's cells are full of electrolyte(add distilled water if necessary)FZRrider09 wrote:yes whats it supposed to be reading at idle and at throttle? Thanks!
Take alook at you voltage regulator (under right hand seat fairing. if it looks like a tin can filled with rubber compound go buy another on e-bay for any late model yamaha and bin the old one.reelrazor wrote:A) charge it up on a low amperage charger (2amp or less) overnight. (make sure the battery's cells are full of electrolyte(add distilled water if necessary)FZRrider09 wrote:yes whats it supposed to be reading at idle and at throttle? Thanks!
b) idling , the voltage will be real close to the battery's charged voltage (12.7 or so)
c) at 3000rpm the voltage should start climbing...and should be at least 13.2, 13.4..somewhere in there....and shouldn't go over 14.2 or so.
