Valve springs?
Valve springs?
I just did my valve clearences about a week ago cause they were way out of spec. All my exhaust valves were really tight and now it feels like its already starting to have the old problems again. Could this be caused by bad valve springs? If not what?
- 100+ Posts
Re: Valve springs?
It took about 3 min straight of cranking to start and it had terrible top end. I resoect the valves cause all the exhaust were really tight and cylinder 2 intake were loose. Helped a ton and now it seems its gradually heading back to the same problem.modkingfzr600 wrote:what are the "old problems" that you are having ?
