Ring end Gap
fink
Ring end Gap
Post by fink »
How does one measure it?
Any tricks for getting the rings off the pistons without scratching the piston crown or skirt?
90 FZR 600 - 63K miles, needs a cylinder head
94.5 ducati 916, 2002 KTM250, 1990 KDX200, 1991 GSF400 (needs carbs)
modkingfzr600
100+ Posts
100+ Posts
Re: Ring end Gap
Post by modkingfzr600 »
use ring expanding pliers to get them off without scratching the pistons , to measure ring end gap you will need to insert the ring down in the cylinder by itself, shove it down about 1 " deep in the cylinder and make sure it is square with the cylinder walls " same distance down all the way around the ring" then use feeler guages and measure the ring end gap ( the gap between the two ends of the ring) i'm sure you already knew the last part.
fink
Re: Ring end Gap
Post by fink »
Thanks! Everyone says, oh yea, measure the ring end gap to see if they are below spec... but nobody knows the correct procedure to actually measure the ring end gap.
I need new friends.
It is pretty much a given that I will need new rings, do you happen to know anywhere to get them at under $90/piston?
modkingfzr600
100+ Posts
100+ Posts
Re: Ring end Gap
I have been seeing quite a few brand new sets on ebay lately for pocket change, i would look there first.
fink
Re: Ring end Gap
Post by fink »
I got one set for $20. Saved me $70! Only took four years to find one, so in another 12 I should have enough for the rebuild!
Should I be looking anywhere other than ebay?
modkingfzr600
100+ Posts
100+ Posts
Re: Ring end Gap
well, if you can't find new ones on ebay ....... take a jar of vaseline and your wallet and go to the dealer.
fink
Re: Ring end Gap
Post by fink »
Unfortunatly, that might be the only option.
I never could understand why Yamaha rings and pistons are so expensive. I don't think I paid $90 for both sets of ducati rings.
