piston problems
piston problems
does anyone know how to tell if your rings are bad ? my bike is smoking and rage and I took it apart today, looks like a screwed up head gasket(homemade) ,cylinder walls look fine ....any help would be great !!!! thanks...
I dont ride fast ...I fly really low .....
Re: piston problems
put it all back together and get a compression test kit and test teh compression on each cylinder. I'm not sure on the specs I think if your over 120 you are ok.
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
Re: piston problems
we already did the test and I was at 160 psi ,,with wiesco pistons , should I have burns on the walls or scars or movement in the pistons when there all the way up ?
Re: piston problems
160 is great. Burn marks? maybe without scoring but if there is any scoring i would retest for compression because gouges (scoring, or scars) on the cylinder walls is no good man.
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
Re: piston problems
there isnt any scoring ,but there is little movement when the two outside cylinders are all the way up ,I think the headgasket is my problem ,it looks like the previous owner made it in shop class,does anyone have a pic of a new one ?
Re: piston problems
replace it and see I wouldnt worry about the pistons If there is no scoring the rings and pistons do have a minute amount of play in them
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
