Oil Filter Converter/Adapter
Do they/have they/can I make a adapter so I can buy the same filters for every other year fzr besides 89? I want to use a spin on filter. There has to be some way to make the 89 use one. Please any help is appreciated. Paper filters FTL.
Re: Oil Filter Converter/Adapter
Yamaha converted the FZR600 to a screw on oil filter in the mid 90's. There are 2 main parts you need to do the conversion. First is the adapter plate (3TJ-13461-00-00), second is the union bolt (90401-20145-00). There is also an o-ring that is needed (93210-87723-00). The parts are listed under as "oil cooler" in the parts fiche even though there is no real oil cooler.
Damn its 70 dollars. Well this is going to be one expensive oil change.
