Oil Light
Re: Oil Light
You checked the oil level in the window when the bike was vertical? If so, then you may have a bad sensor. I never relied on mine too much anyway. I always checked before and during rides.
Re: Oil Light
I would bet its a bad sensor. Mine always cam on when the bike was low on oil like its suppose to. But when added, went out.
Re: Oil Light
Where is the oil sight glass for a 95 fzr 600? ANybody got a picture?
95' Yamaha FZR 600
Re: Oil Light
It's on the right side of the bike (if you are sitting on it) Can be seen through the small hole in the bottom of the fairing. Look at rage's avatar pic, it's the small hole
92 FZR600
Dual Headlight Upper Swap
Clear Taillight w/LED Bulbs
More To Come
More To Come
Re: Oil Light
Got it, I looked after I rode for a minute and had the bike sitting vertical but could not really tell to much. I think I am going to change the oil again next week and see what it does
95' Yamaha FZR 600
Re: Oil Light
Mine's about half way up when I do an oil change. It would be nice if they put lines though, huh?
Re: Oil Light
Here's a pic from my service manual.
Re: Oil Light
There's two 'dots' cast into the aluminum right next to the sight glass. The lower one is the 'low' level , the higher one is the 'high' level.ashtong63 wrote:Mine's about half way up when I do an oil change. It would be nice if they put lines though, huh?
Mind you, check it with the bike upright (not on sidestand), level(front to back), and while warm (not running but after a minute of sitting to allow 'drainback'). I kneel on my left knee, grab the right handlebar and pull the bike vertical while watching the window.
