Bike died - won't start
Re: Bike died - won't start
Sounds like a firing problem to me , when the starter fluid was sprayed and went into the cylinders , if that engine had some spark , it should have fired , popped , tried to run or something ..... sometimes even if the firing system is working and the spark-plug is fouled completely , It will not fire a mixture of fuel ...... sometimes a closer inspection by the repairman needs to be in order . Not being there and looking at it can take a little more time to solve .
