FZ1 Shock?
deernet
100+ Posts
100+ Posts
FZ1 Shock?
Post by deernet »
So is the FZ1 rear shock a direct bolt on? I've heard conflicting answers. Do you have to have custom spacers machined, or can you just use washers?
I'm assuming this shock would be stiffer than stock, but I believe it has alot more adjustment?
I'm wondering which would be easier to install, this or the R6 shock, which I believe has to have custom spacers machined.
haunter
Re: FZ1 Shock?
Post by haunter »
you can use washers if you want
has more adjustment, better valving but a weaker spring
you have to grind a lil bit off the inside of the bottom of the stock spring to get it to fit on the FZ1 shock
deernet
100+ Posts
100+ Posts
Re: FZ1 Shock?
Post by deernet »
So you have to swap springs?
Re: FZ1 Shock?
Post by sweekster »
That is correct. FZ1 spring isn't heavy enough to support the old fizzer. So unless you want to go spend money on a brand new spring, swapper in the FZR spring is the best bet. Needs a few millimeters filed from the top and bottom of the spring but you golden after that.
boyoboy
Re: FZ1 Shock?
Post by boyoboy »
good day,
is the bike you did the fz1 shock swap on a 400 or 600?
is the 600 shock spring stiffer than the 400 spring?
the fz1 shock spring is listed as 7.6kg/mm. does anyone know the shock spring rates for the 400 & 600?
it was mentioned a few mm had to be ground off the fzr spring. is this grinding done to shorten the spring length or is it width narrowed?
thanks.
shredex
Re: FZ1 Shock?
Post by shredex »
alls i know, is that i have a fz1 shock with fzr spring on my bike...no clue how it got there...its just there and im happy with it.
there is one problem though. I have custom bones that allowes me to either raise/stock/or lower the rear.
i have it set to raise the rear and the bottom of my shock touchs the swingarm and i believe its made a grove into it...but thats just a problem if you raise it...iv got probably 3K miles on it like that and its been fine...
the_finch
Level 8.5
Level 8.5
Re: FZ1 Shock?
Post by the_finch »
I posted an answer in the other FZ1 shock thread a minute or two ago.
http://www.fzronline.com/forum/viewtopic.php?f=7&t=3720
A write up on installation, gotcha's, and tuning is on the way.
1997 FZR600RJ
boyoboy
Re: FZ1 Shock?
Post by boyoboy »
shredex wrote:alls i know, is that i have a fz1 shock with fzr spring on my bike...no clue how it got there...its just there and im happy with it.
i was wondering, does the ride height remain the same with the FZ1 shock - i would require the same height or even better if its raised up a bit. what do you think about the ride ht. with the stock dogbones?
the_finch
Level 8.5
Level 8.5
Re: FZ1 Shock?
Post by the_finch »
That's one thing I checked when I did mine...ride height remains the same. Geometry stays the same. Makes it easier to figure what length dogbones you need to raise/lower your ride height, as it is the same as stock.
1997 FZR600RJ
boyoboy
Re: FZ1 Shock?
Post by boyoboy »
hi,
ride height remains the same - excellent info for me thanks.
it looks like it would be fairly simple to build / install some dogbones that would raise the rear.
how much shorter would i make the dogbones to raise the rear about 1/2" to 5/8"? anyone know?
haunter
Re: FZ1 Shock?
Post by haunter »
not sure for that little of a raise.....
boyoboy
Re: FZ1 Shock?
Post by boyoboy »
haunter wrote:not sure for that little of a raise.....
not sure for that little of a raise....do you know how much of a shorter dogbone = greater ride height, then maybe i could do the math and get a rough estimate for what i'd like?
haunter
Re: FZ1 Shock?
Post by haunter »
its in the wiki, I think its 2.4m raise per mm of shorter dogbone
shredex
Re: FZ1 Shock?
Post by shredex »
of got the custom bones with three settings... for lowering/stock/and raising...mines set on the raise.
but yes, its in the wiki about how much hieght you gain per whatever shorter the bone is.
here ya go
http://fzronline.com/wiki/doku.php?id=dog_bones
