Identify my header..
FizzNation
Post by FizzNation »
Hey there i finally got some pics of my header.
let me know what it is
cad600
Re: Identify my header..
Post by cad600 »
:headscratch: Don't know. It is not a Yoshi header as they are 4 to 1.
shredex
Post by shredex »
isnt that a three peice header?(Pipes 1&2, 3&4, and the mid?)
someone on the board has it...I remember the pics when they had it taken apart and painted.
edit*
Check with board member "mrfreeze5" I believe he has the same header as you.
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
D&D made a 4-2-1 and I think the SS2R by V&H is a 4-2-1...
Whatever it is, a little sandblasting and some hi-temp paint each fall will keep her in decent shape.
Fizzinatorr
Level 6.5
Level 6.5
Post by Fizzinatorr »
it's a D+D :thumbsup:
dru86
Level 1.5
Level 1.5
Post by dru86 »
+1 D&D got one on my bike. If you can weld or know someone who can weld the three pieces together, it makes getting in on the bike alot easier and also stops it leaking around the joins.
