Possible vapor lock?
fzrbrandon
Level 7.5
Level 7.5
Post by fzrbrandon »
Hi all,
So I rode the bike in to work yesterday and she ran great as I hoped she would. When I got home I turned the petcock OFF thinking that I might not ride in today. Well, I in fact DID decide to ride today so I pulled the bike out, applied full choke, turn the kill switch to ON, hit the starter button, and she fired up within about a second. I'm guessing it took about 4 or 5 minutes for the revs to kick up to about 3000 at which point I closed the choke all the way. I want to mention that I would NORMALLY leave the choke applied for another couple minutes or so before closing it. So I sat there for another couple minutes with the bike running at idle. I then noticed it starting to sputter a little bit. I though to myself, "Crap, the petcock is turned off!" So I reached down and turned it on. In the past I never really turned the petcock off. For some reason I thought that I would start doing it for whatever reason. I sat there for another minute or so then put the bike in gear and started making my way down the driveway. Right away I noticed that it seemed a little rougher just off idle when letting out the clutch but I just figured she was still a little cold. I was stopped at the end of the driveway waiting for traffic to clear when I started to let out the clutch to get going - then the bike died. I hit the starter switch again and she fired right back up. At this point I heard a pop coming out of the exhaust. So I started revving the bike a bit and I noticed that she was indeed backfiring. I got off, took off my helmet and listened closely and noticed that the bike was still running as if it was running out of gas. After letting it run for another 5 - 10 minutes I put her back in the garage and took the truck in to work. Anyway, sorry for the long explanation but I was wondering if this could just be a case of the fuel system being vapor locked from starting to run out of gas? I thought I read somewhere a while back something about it taking 15 minutes or so for the bike to run smoothly again after switching to RESERVE when the bike starts running out of gas. Could this be a similar type of thing?
Thanks!
Brandon
Image Image
http://www.fzrbrandon.com
R3TARD
Level 4.5
Level 4.5
Re: Possible vapor lock?
Post by R3TARD »
stuck float???? did you check ur plugs?
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
fzrbrandon
Level 7.5
Level 7.5
I actually just put the carbs together Wednesday night. They've been rebuilt and cleaned a couple times over the last 3 or so weeks for various reasons so I'm fairly sure the floats / needle valves are fine. The plugs should be okay also. I checked them about a month ago or so and have only put about 18 miles on the bike since it's been put back together (2 trips to work and a couple test runs). I'll probably pull them to have a look again if I can't get her running smoothly again. Anyway, she ran great yesterday. The only thing out of the ordinary that happened was the fact that she started running out of gas because the petcock was turned OFF (which I quickly turned ON).
Thanks!
Brandon
Image Image
