Fuel pump pressure, car pump?
BAT
Post by BAT »
I've read on here I can use an auto pump. How many psi do the fzr carbs need? Would this pump work?
http://store.summitracing.com/partdetai ... layPrice|0
I don't know if it would need a regulator or not.
93 fzr600 full D&D,jet kit,open K&Ns, 13T front
2006 GSXR 600
DonTZ125
Moderator
Re: Seized fuel pump
Post by DonTZ125 »
My FZR250 pump has a 1.5psi output; I haven't heard that the bigger bikes use a higher pressure.
Re: Fuel pump pressure, car pump?
Post by sweekster »
You can use any 2 wire self regulating 5.5 to 9 psi fuel pump.
BAT
Post by BAT »
Ok, I'll order the 7psi one from summit. Its 35 gph. I wonder how much less it'll be with less amps?
2006 GSXR 600
