ok guys, I know some of you have been waiting on me to actually start the carb swap that I have been talking about for months. You'll be pleased to know I started it today because we start work late on fridays, so i had time this morning..woohoo! I did some measurements of the carbs and they are considerably larger. The measurements of the outside diameter of the bottom of the carbs is about 1 6/10 inches(41mm ish) (my mic goes in tenths of an inch and I'll put the exact measurement up later when I get back to my house today). The inside diameter of the little intake manifolds is about 1 4.5/10 inches(37mm ish). Also, the outside diameter of the intake manifolds is about 1 7/10. The new carbs will flow more air than the FZR ones did, add 2/10's of an inch to your diameter. That's a LOT more air flow!!!
So what i'm planning on doing instead of cramming the carbs into the manifolds is buying some radiator hose that is a similar diameter and putting some clamps on it then fitting it around the carbs and slipping it AROUND the manifolds instead of the carbs going inside of them. This way I don't rip my manifolds that already have small cracks. The carbs will sit a little bit higher than normal, then if you add in the height of the velocity stacks they just barely fit under my R6 tank, it's a really tight fit. I have to figure out how to get filters on top and I already have an idea in the works that involves buying individual K&N filters and putting them around the velocity stacks. But I don't know how much more height that will add to the setup. You guys with the yzf600 tanks shouldn't really have an issue with the carbs being taller because that tank has more room in the carb area. And I think the stock FZR tank cover has plenty of room as well. I'm also going to mount them to something to make sure they stay sturdy, i'm not trusting the radiator hose to support them.
Cables have to be routed to the left side, around the forks, and under the tank cover (or gas tank if you did a swap). On the YZF600 they are routed around the right fork, under the triple tree, above the radiator, under the frame and into the carbs. I tried to route them this way...the cables kink and the throttle sticks. Also, there might be an issue with the grip end of the cables on a stock FZR handlebar, the piece where the cables go in that attaches to the grip has a notch where it fits into the YZF600 handlebar to hold it in place, this isn't an issue for me because I have a YZF600 handlebar that came with my box-o-YZF600 parts, had some trouble making it fit in the FZR clamp due to the FZR bar being notched so it can fit in the clamp, the notch is in a different place on the YZF600 bar. I just ground the metal stub down in the clamp so the YZF bar would fit in the clamp. Problem solved
Anyway, that's it for now, i'll put pics up tonight with more exact measurements, i took pics of the micrometer beside the carb bottoms with the size of the manifolds mic'd, so you guys can see the difference in size vs reading "2/10's of an inch larger..blah blah blah." Anyway, subscribe to this thread! Happy modding guys!
