to whomever has done the 03 - 05 R6 swingarm swap...
match417
Level 8.0
Level 8.0
Post by match417 »
So, a friend of a friend at a machine shop is going to make me some spacers like the ones here http://www.fzrarchives.com/ipb/index.ph ... opic=37748, and I just need the measurements of them. I haven't picked up the swingarm from my friend and I don't want to pull the swingarm bolt out of my bike. I need inside diameter, outside diameter, and length. I know there are a couple guys on here that have done it, hopefully someone has the measurements. Thanks!
manveru
Level 3.5
Level 3.5
Re: to whomever has done the 03 - 05 R6 swingarm swap...
Post by manveru »
it depends how much grinding you do to the frame.
95FZR600
Post by 95FZR600 »
manveru wrote:it depends how much grinding you do to the frame.
You only have to grind on the frame if your doing the R6 swinger like I did. The YZF 600 swinger is only grinded on the swinger itself not the frame.
manveru
Level 3.5
Level 3.5
Post by manveru »
the r6 you have to grind a bit on both, at least the 03-05, or else just grind a lot off of the frame
