Dynaojet kit question
So my bike came with the dynojet kit installed, but when I pulled the carbs the original jets were still installed. However, the slides were drilled and the needed was installed. So my question is what jets need to be installed and do they need to be from dynajet? More specifically, what size mains, and mids should be installed?
Currently running stock:
main 107.5
mid 52
low ?
thanks
if anybody has some jets to sell that would fit my application I could use them.
main 107.5
mid 52
low ?
thanks
- Level 2.5
Re: Dynajet kit question
Hello icontender...If they said a Dynojet kit was installed then look at the needle..if it has 6 slots then it has the needles but the main are deffinatley stock....
Question 1: Do you have stock air filter or pods?
Question 2: Exhaust? Slip on? Full exhaust?
I need to know this to see maybe what main jet you need...and you dont need to change the slow jet...
I have just about any jet..since you are a member and live just 3hrs away I will give them to ya...
2 wheels:
1994 Yamaha FZR 600,stage 3 dynojet,Supertrapp 16 disc exhaust,14-46 gear.
3 wheels:
1983 Honda Atc 200, superswampers, jetted,cobra exhaust..(IT REALLY FLOATS).
1984 Honda Atc 200E, Dead At the moment......
4 wheels:
1995 Chevy K-1500 Ext Cab (Blue) 2 layers of 5% tint...10in rims,33x12.59x16 mud terrian tires, dual exhaust..
I have a full V&H exhaust with K&N air filter. I do have the dynajet needle (6 slots) and the slides are drilled already as I compared them with my stock carbs.
What do you suggest I run? I appreciate it.
corey
corey
- Level 2.5
I would try 130's....and turn you A/F mixture screw 2 1/2 turns out.....I will get them tonight when I get home and send them tomm....
2 wheels:
3 wheels:
4 wheels:
yeah i would run 130's that is what i got in mine and i got a full v&h ss2r system with k&n pod filters
airtech R1 solo tail, russell racer front brake lines, dynojet stage 3 jets, K & N pod filters, V & H SS2R exhaust system, 89 gsxr 750 rear wheel
- Level 2.5
Yea, gonna send them to him tomm...maybe I can get him running good again..
2 wheels:
3 wheels:
4 wheels:
Here is the best set-up I had:
V&H Supersport Exhaust - Full
K&N Filter
New Factory pro emulsion tubes
DynoJet Needles (clip #3 - kept the 7k RPM blip away!)
DynoJet 126 Mains
Floats set to 22.5mm
A/F were all over, but adjusted them to match each other using a IR Temp Gun
Removed the Air Intake (Frame Coolers) They did have an effect at higher speeds. Left the frame holes open.
Slides were not drilled
All EXUP items were removed and plugged, if necessary
Screamed like a bat outta hell!
Course the 14/49 520 set-up didn't hurt either!
I tried 130s and they gave me problems. Too much fuel perhaps.
Adding some of my photos if people are curious as to what we're discussing.
K&N Filter
DynoJet 126 Mains
- Level 2.5
Hey RAGE!! What is the jet next to the main called....The slow jet is in the hole..Is is a "MID" jet? And you moving you needles got rid of the 7k blip? I tried all slots and finally had to go with the stock needles......I want to try Factory Pro needles......they dont have that steep jump in them...
2 wheels:
3 wheels:
4 wheels:
That jet is the starter jet.
The one in the hole is the Pilot Jet.
The Jet Needle controls the mid range usually after 1/4 throttle up to WOT.
This graphic helps understand what most items help in what THROTTLE range. I don't believe that abrupt taper on the DynoJet needles does anything until WOT. Usually it's around 1/4 or slightly higher where people have the issue at 7k RPM.
- FasterThanUr
- 100+ Posts
With all this talk about jet's and what not I decided to pull my carbs and see what mine had going on in there since the P/O said it had a jet kit.Now im just confused I know there newer carbs because they have a tps sensor and also they still had the caps on the mixture screws.I drilled and poped out the caps.# 1 was at 1 1/2 # 2 & 3 were at 2 and # 4 was turned all the way in.I turned them all to 3 1/2 and now the throttle response is a million times better.Now on to the needles and jets.The needles have no clips and looks like the factory pro needle.The needle has 3NFC I believe it was stamped on them.Is that a stock needle?And now what really gets me is the main jet is a 155.I thought I was seeing things but looking through it the hole is bigger than all hell.Now I would think the bike would run like crap with those jets in there,but I have hooked up a o2 sensor and AFR gauge.At idle it's a little on the rich side,but at WOT it drops back in to the ideal range.The P/O did race it so maybe he cheated and put a big bore kit in there and failed to mention it.It's a lot more torquey in the bottom end than the lady friends F4I and will walk all over it up to about 100MPH.I just figured it had to do with the gearing,but maybe theres more going on there than I thought.
Ok this is turning into a book so Im gonna leave it at that
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I hooked my brake light switch to my throttle,so when I hit the gas everyone would slowdown and I would be gone
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
If you have 155 Mains and a TPS, then you have 97+ YZF600 carbs on there.
- FasterThanUr
- 100+ Posts
I figured they were probably Yzf carbs.Is 155's what the came with stock?ragedigital wrote:If you have 155 Mains and a TPS, then you have 97+ YZF600 carbs on there.
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
- FasterThanUr
- 100+ Posts
Oh I just found the specs for the carbs.Not sure what year but the pic of the bike has the seat 97
36mm Keihin downdraft carburetors
• Main Jet #155; CA mdl = #148
• Main Air Jet #80
• Jet Needle #1,4: N3FC #2,3: N1YF
• Needle Jet 2.6
• Pilot Air Jet 1 #140
• Pilot Outlet 0.9
• Pilot Jet #38
• Main Air Jet #80
• Needle Jet 2.6
• Pilot Outlet 0.9
• Pilot Jet #38
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
Is it a YZF600 motor?
The reason you can do the "ram air" is due to the YZF carbs. You can't do that with stock FZR carbs.
I had 110 mains in the carbs before but from 1/2 to 3/4 it ran like crap. This was basically the cruising range. So I either had to driver dangerously are accelerate all the time. 3/4 to WOT was bad ass though. I am hoping the 130 mains will cure this 1/2 to 3/4 problem. However, looking at the picture posted (one with the graph) what is the needle taper?
