Hey guys.
I noticed that my signal switch is getting harder and harder to move left and right. Today I sprayed some white grease in it , and now most of the time I can't push it back in to stop blinking.. Any fix or suggestion for this??
P.S It moves easier now , left and right but gets stuck and doesn't want to be pushed in..I have to keep trying to push it in before it eventually goes in..Hope it makes sense
Signals issue?!?
Signals issue?!?
1995 ,FZR 600,Factory Pro 1.1Ti Jet Kit, Yoshi slipon,K&N filter,elevation 4200 ft above sea level.
Carb settings: Main Jet 110, Starter Jet 52.5,Needle @ 3rd position,23m Floats,about 3 turns IM Screws.
80's-90's,Rap..music.?? http://www.last.fm/listen/user/unsmenar/personal
- megaloxana
- 2000+ Posts
Re: Signals issue?!?
Yeah I never encountered this. My guess is just wear and tear on the switch. I see this as an excuse to do R6 Control swap
'92 FZR 600
Take the switch apart & clean it thoroughly use a fine emery to remove any slight burrs caused by wear over the years.yamaboy wrote:Hey guys.
- shredex
- 2000+ Posts
you might need a whole new box. there might be grim in it.yamaboy wrote:Hey guys.
if you know how to, take it apart and clean the switches.
if it doesnt work or you cant do that, Iv got one that I can sell to you for like 5 bucks. I dont know what shipping would cost.
I'll open it this week sometimes and check it out. It's those 2 screws , right??
Thanks guys
Thanks guys
