What oil are you running?
cell
Post by cell »
What Brand/Weight oil is everyone running? I need to change mine, I believe that is causing some slippage of my clutch plus I need to fix my pan leak. Anyways, just trying to see whats better for the Fizz.
D&D Full Exhaust
YZF tank swap, 99-00 R6 Tail swap
R6 Front Calipers, SS Brake Lines, YZF Master Cylinder Swap
YZF/R6 VR
04 GSX-R 600 Mirrors
Integrated Tail Light, Flanders Front Flushmounts
yamaboy
Level 1.5
Level 1.5
Re: What oil are you running?
Post by yamaboy »
What's happenin'?
I barely changed my oil with Valvoline 10w40 4 stroke Motorcycle oil.. It's pretty cheap (found at Checkers or Autozone) , and you can't go wrong with Valvoline. Here's some specs on it:
http://www.valvoline.com/pages/products ... product=76
I also changed my oil filter with a K&N .. It has a "nut" welded on it so you can use a ratchet with an extension right thru the exhaust pipes.
My bike sees revs close to redline pretty often so I trust Valvoline..
Good luck
1995 ,FZR 600,Factory Pro 1.1Ti Jet Kit, Yoshi slipon,K&N filter,elevation 4200 ft above sea level.
Carb settings: Main Jet 110, Starter Jet 52.5,Needle @ 3rd position,23m Floats,about 3 turns IM Screws.
80's-90's,Rap..music.?? http://www.last.fm/listen/user/unsmenar/personal
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
Always used Yamahalube 10w-30 or 10w-40 in the FZR. The CBR gets AMSoil 10w-40 MC.
ShogunTX
Level 4.5
Level 4.5
Post by ShogunTX »
Anyone using Lucas Oil additive?
haunter
Post by haunter »
I use Rotella non syn in the 600 currently (yay 15 buck oil change with filter)
used Rotella Syn before, thought it was making my clutch slip but my MC was the culprint
used Mobil 1 Racing 4T as well. cost the same as amsoil.
FasterThanUr
100+ Posts
100+ Posts
Post by FasterThanUr »
I use Valvoline VR-1 50 wt with a K&N filter
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I hooked my brake light switch to my throttle,so when I hit the gas everyone would slowdown and I would be gone :headbang:
YAM93
Post by YAM93 »
Spectro Golden 4 10W-40 semi-synthetic (a bit expensive though)
never any problems here
also noticed this oil seem to help transmission shift more smoothly also
cell
Post by cell »
YAM93 wrote:Spectro Golden 4 10W-40 semi-synthetic (a bit expensive though)
Where can you find this locally? Napa perhaps?
D&D Full Exhaust
YZF/R6 VR
YAM93
Post by YAM93 »
Any really good motorcycle shop or dealer. if not they should be able to order it from a local distributor.
you won't find it at any place that sells car oil. i think it's around 11 - 12 bucks a quart... could be more now, not sure.
you can also get the standard type... it's a lot cheaper but still is better for transmission. i just went nuts and got the semi-synthetic expensive stuff just to try it out. the regular kind is VERY good and probably 7 or 8 bucks a quart instead.
if you can't find it try some Amsoil.... they are really great also. I use MAXIMA oil in my motocross bike, that's some good stuff too. Maxima Premium is about $20 a gallon from Dennis Kirk.
NHFZR600
Level 2.5
Level 2.5
Post by NHFZR600 »
another oil thread????!!!!!!! bonkonhead banghead banghead banghead banghead banghead banghead banghead banghead banghead banghead banghead banghead :swear :swear :swear :swear :swear :swear :swear :swear
Leftover 07 Silver Ninja ZX6-R
**SOLD**
1990 FZR 600 Satin Black / Metallic Black Frame / Metallic Copper wheels
- Mods -V&H PIPE & HEADERS - 1999 R6 TAIL - 2001 UNDERTAIL - INTEGRATED LED TAIL LIGHTS - 2000 YZF TANK - 1995 YZF FRONT SUSPENSION AND GUAGES - MICHELIN PILOT POWER 120/60 ZR 17 - 1995 YZF REAR SWING ARM AND WHEEL W/HUGGER - METZLER ROADTEC Z6 170/60 ZR 17 - Xentec 8000K HID HEADLIGHTS - WHITE LED LIGHTING KIT
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
NHFZR600 wrote:another oil thread????!!!!!!! bonkonhead banghead banghead banghead banghead banghead banghead banghead banghead banghead banghead banghead banghead :swear :swear :swear :swear :swear :swear :swear :swear
Have there been a lot? I don't recall too many.
yamaboy
Level 1.5
Level 1.5
Post by yamaboy »
Haha, I started one not so long ago.. :deadhorse:
95FZR600
Post by 95FZR600 »
I run Royal Purple 20w50 in my fzr but in the intruder I use castrol MC oil 10w30.
NHFZR600
Level 2.5
Level 2.5
Post by NHFZR600 »
oil threads were a big topic that came up atleast once a month on the archives.
**SOLD**
cell
Post by cell »
Yea yea yea... I tried searching for oil threads but the search engine on this forum isn't exactly friendly. Anything too small and it has a seizure, and anything that is said to often makes it want to punch a baby. So instead, I was lazy and started yet another... oil thread ... :-D
D&D Full Exhaust
YZF/R6 VR
