Losing low beam
- HeadRush
- Location: IL - My governor is dumber than yours, trust me.
Losing low beam
I'm sure that this has been posted elsewhere, but I can't find it. So here it goes.... I have a 92 FZR and for some reason I keep blowing my low beam headlight, but the high beam runs like a champ. Anybody know of any issues that may cause this? I have no other electrical issues besides this - everything else runs great.
Dangerous when bored.
Re: Losing low beam
if it blows at a higher rpm check your vr or the voltage at the bat at that rpm might be overcharging
- HeadRush
Re: Losing low beam
It's been blowing at idleharo504 wrote:if it blows at a higher rpm check your vr or the voltage at the bat at that rpm might be overcharging
Re: Losing low beam
still check the voltage if its blowing multiple bulbs then its not usually the bulbs so if you have much more than 14.5 volts then its the vr usually. couldent hurt to check atleast you can rule it out.
- HeadRush
Re: Losing low beam
Will do, thanks.haro504 wrote:still check the voltage if its blowing multiple bulbs then its not usually the bulbs so if you have much more than 14.5 volts then its the vr usually. couldent hurt to check atleast you can rule it out.
