I looked in the stickies for a how to on checking the vrr for correct ohm readings but didn't see it. Using this photo
I'll explain what I did. Someone correct me if I'm wrong. Both top pins and the bottom right are wires from the stator. I checked each of these pins across and got 1.1 M ohms across the three (1-2 1-3 2-3) next I checked for the diode inside. Negative on case, pos on bottom left pin. Overload. Pos on case, neg on bottom left pin, current flowed. To me, that seems like the flow is backwards. Is the vrr correct on the diode placement or is it backwards?
Ps the pic won't rotate for me. Rotate 90* for correct pin orientation
Sent from my LG-H811 using Tapatalk
