brake pad change went bad
FZR_600_90
I was due for new pad so i proceed to remove them on one side, the inside piston were stuck causing the pad to be used uneven (inside was almost to the metal and outside has lots of meat left) so i sprayed some wd40 around the inside piston to Free them up and pushed them back in...while i did that the outside piston popped out and major oil leak did follow...what should i do now ?
Re: brake pad change went bad
Put the piston back in. Add brake fluid, bleed brakes.
FZR_600_90
Its all good now but didnt had the time for a test drive yet thanks
