first question what are you refering to ?
i didnt install the hand grip yet but i might do it today !
the gear indicator is not on yet either but as soon as i get around it ill let you know
im probably gonna get the delkovic ss70 shorty muffler just cant make my mind yet i dont wanna get stupid exhaust ticket
for the snow i still can ride so it doesnt bother me as much but i cant wait for the summer
and if you look in the few first picture i had the same side mirror on both side and theyre really ugly imo
my fzr '90 build
- willandrip
- Level 7.0
Re: my fzr '90 build
The brake and clutch levers you ordered from china .
I saw you had 2 left mirrors .What I was stating was ; a left mirror on the right gives a better view.
This was more for those who probably wondered why 2 lefts were fitted. !
The lever look like theyre good quality really but i didnt install them her kinda afraid to do it as i want them install proprely i wouldnt want them to fail on me
While im driving because i did wrong on the installation
- willandrip
- Level 7.0
Cannot really install them incorrectly; they fit or they don't.
It is only a shouldered bolt and a lock nut.
Do ensure there is a little free play on the brake lever where it meets the master cylinder piston.
If it is pressing on the piston slightly it can ,over a few applications hold the brake on .
It needs a little free play to release the pressure at each stroke.
ive tried to put the handle on but the inside is to small in diameter to get it on i guess ill put them for sale
as for the handle i took a good look at it but the design seems completely different
strange because they were listed for a fzr so im kinda pissed about it, my brake lever is bent because it felt on the side when i wasnt there so id be happy to change it
The grips will fit. The only sizes are 7/8 and 1" really and 1" is reserved for Harleys pretty much. They are going to be tight and one side is going to be bigger than the other because of the throttle. You will need some hairspray or soapy water to get them on. They aren't going to just push.
Do YOU Scopper?
Thanks for the advice
- Harrysf707
- 100+ Posts
I also found out that isopropyl alcohol (rubbing alcohol) works really well when putting grips on, plus it evaporates fairly quickly.
1993 FZR 600 w/ 92' front fairing swap, 520 conversion, Yoshimura R&D Exhaust, RaceTech springs.
