Quick Shift Inline Sensor - Update
Posted: Mon Nov 11, 2013 7:08 pm
As some of you may recall (it's been a while), I've been investigating the possibilities of making and selling inline sensors to go with the Quick Shift controller I've designed. The biggest hold-up has been in finding a machine shop that will actually give me a price for the machined bits that hold the actual sensor!
If I buy one set of machined parts, it will cost me just under $1000. Ahem.
If I buy a set of components for a run of 10 units, I need to charge $250 each. Moving further along, if I someday become famous enough to buy in lots of 50 sets, I can sell them for $150 each and keep the same margin per unit.If there is sufficient interest, I will do a run of 10 and the soon-to-be-famous TTR Ignition Inline Sensor will become a reality.
What you get for your $250 (plus shipping):
- a little box with wiring that plugs straight into your TCI and wiring
- a little aluminum tube with steel threaded rods sticking out that easily and directly replaces your shift rod
- wiring that runs from the little aluminum tube and plugs straight into the little box
For an extra $25, you get a built-in rev limiter that can be used for launch control, as well as a bar-mounted push button and wiring that plugs right into the button and the little box.
Launch RPM and shift cut time are easily adjusted using pots in the controller box.
I have two guys who've used the quick shifter with push button, and are delighted with it. One fellow has used also the launch controller, and just loves it. (Both comments on the FZRArchives)
Any takers?
Any takers?
