I have a few FZR600 3HE engine parts for swap. I am after FZR400 3TJ parts really and am prepared to do straight swaps as this stuff is just blocking up my workspace.
What I have:
Oil pump - whole unit
Sump
Crank with rotor on one end and starter gear on the other
4 x 3HE Conrods
3HE cylinder I have got 3 (!?!) pistons. They have 1.0 stamped on the tops - from two strokes I remember this meant 1.0mm oversize but I didnt think oversize FZR pistons were available?????
Camshafts with camchain sprockets on them
Gearbox parts - lots but don't know If I have a whole one.
Completly bare/stripped cylinder head - no valves or anything fitted other than spark plugs and old carb inlet stubs.
Set of paired engine casings with gear selector forks in and gear drum
What I need:
FZR400 3TJ - the wiring that goes between battery and starter solenoid - it also has a little take off wire that goes to the Main fuse.
FZR400 3TJ - front brake lever
W.H.Y?
Dont want to take cash for these parts - would rather swap for 400 parts. If you really need one of these bits and you can collect then come take it!
Chris
