Wanted - FZR600 airbox
ronny86
100+ Posts
100+ Posts
Post by ronny86 »
after an airbox, seen some on a well know auction site but thought id try my luck here and try get it a bit cheap WOOT
the 2nd pipe that sits on the carbs on my airbox is damaged so its not air tight and thibk this is causing bike to run a bit rich so need to change it i reacon
Re: Wanted - FZR600 airbox
Hiya, Ronny!
First, an air leak will make the bike run lean, not rich. If you're rich with an air leak (!) something else is going on. Second, those inlet pipes / stacks / joints are replaceable. Part number is 3HE-14453-00-00, US$15.76 MSRP at any Yamaha stealership, but you can probably pick it up cheaper online.
Of course, "cheaper online" can sometimes be a little meaningless when you start including shipping... :deal:
ronny86
100+ Posts
100+ Posts
Post by ronny86 »
81quid for new rubbers o.O will a set of 95 foxeye rubbers fit my 90 model? cheers
Do you need all four? A tired carb boot (this goes for the ones on the engine side, as well) can be refurbished by soaking in boiling coolant - don't use the wife's best crockpot, the stuff is toxic after all.
If you have one or two that are well and truly junk, then replace only those ones.
ronny86
100+ Posts
100+ Posts
Post by ronny86 »
just one and i think its past repair, looks like part of its been sliced off with a knife :-/
Ronny
http://www.cmsnl.com/yamaha-fzr600rd-19 ... /B-04.html based in Holland
12 3HE1445300 JOINT. AIR CLEANER 1  € 10.00  plus shipping.
old_fogey
Post by old_fogey »
I'm going to upgrade my ride with dual KN filters, so you can get mine when I do.
My son's ride did the same as your, so I went to my local parts dealer (NAPA here) and bought some tubing with the inside diameter matching the carb throat. All I had to do was trim the rim off the airbox piece (up a bit from the carbs), and everything slid together .. and talk about ar-tight!
Tim
91 FZR 600
94 FZR 600
Yamster
Donating Member
Donating Member
Post by Yamster »
I have got one for you Ronny.
£5+ postage if thats any good to you.
