FS: FZR & R6 R1 parts
Post by thatkid »
I'm having a clear out of stuff removed from my bike & what I bought & haven't used. Photos will be uploaded later. All prices include delivery costs to mainland UK, postage to the Scottish highlands could be more expensive, payment VIA paypal only. Some of these are small parts and easily lost/misplaced.
FZR600
Flasher relay Untested (I have a 2 prong LED flasher, I chopped the OEM plug off and used it for the VR upgrade) £2
Tank £15
Fuel Tap (no tubes on/reserve) £5
Fuel Tap plastic knob (no screw I lost it) £2
Tank cover as seen in my avatar, the front tabs have been repaired (glued @ some point) £15
Tank cover front rubbers £1 each or £1.50 for both
Tank cover front bolts/screws (slightly chewed) £1 each of £1.50 for both
Pillion seat lock/latch (no key) £5
Fuel cap (no Key) £5
I have the key for the locks and can/will dismantle them, you can then adjust the tumblers to fit your key.
I also have another set of carbs (cost me around £10) used for spares (2 mixture screws have been removed for my spare set) The diaphragms sell @ around £70 new. the emulsion tubes are probably shot, but if you need a replacement jet, mixture screw diaphragm e.t.c I'll send you one for the cost of PP + £1, lets keep these on the road @ minimal expense :thumbsup:
138 mm Jack up dog bones (good quality not home made) £12 :yikes: I've just removed these from my bike and measured them (fitted a R6 shock) 1 is 138 mm, the other is 135ish mm f#@*ng PO's suck, they are no longer for sale!
Foxeye
Starter relay/solenoid Untested £10
Flasher relay Untested £2
Battery positive connection (solenoid to battery +) £3
I bought this to modify and fit to my swinger, I have a 400 braced one that I'm fitting @ a later date.
GENUINE YAMAHA YZF600R THUNDERCAT REAR MUDGUARD HUGGER Brand new/unused no chain guard £25
R6 5EB
Riders seat (not the best) £12
OEM Tail light £10
Undertray (needs repair) £10
Aftermarket Undertray brand new/unused with dual stop/tail lamps (not LED) £40
Cluster loom/harness £10
Front mud guard/fender (has a crack) £10
Swing arm crash protectors / bobbins £7
(yes I bought 2 sets)
No Plate bracket (ally) £5
R6 2CO
LED stop tail lamp £18
LED stop tail lamp (small hole in the lens, can be repaired with plastex) £10
R1 I think these came of a 04-06 model
LED stop tail lamp (slight damage to connector) £10
Mal.
tickledawson
Re: FS: FZR & R6 R1 parts
Post by tickledawson »
dont supose you have an r6 rear seat lock (unit and key)
cheers
Post by thatkid »
tickledawson wrote:dont supose you have an r6 rear seat lock (unit and key)
cheers
Nope sorry, I'm also looking in to where that could fit on the FZR, and what brackets would be needed.
Mal.
tickledawson
It seemed to be so much easier to just mod the subframe and bolt a r6 sub on... :D THUMBS UP!!!
