If you ever need to repair a crank case or engine cover you may want to read this:-
http://brazing.com/products/Weld_alum/4043_5356.asp
GH:- Engine case repair welding info
Re: GH:- Engine case repair welding info
I'll add that often the best filler material for welding castings is another broken casting from the same type of unit (same brand/model-think cut up the old/other broken peanut cover you have). This insures compatible alloy.
