Raising Compression?
Okay,Im looking for a couple more ponies out of my engine,FZR600. We are discussing decking the head to raise compression and tune from there.Question is.....Can I use a Cometic head gasket at .010" and get the same outcome? I cant find the stock thickness info anywhere. Has anyone here used the cometic head gasket for the same purpose with good results? or would I be wasting time?
Re: Raising Compression?
Are you going to run 110 octane fuel?
Sent from my SM-S820L using Tapatalk
Skimming the head will raise it slightly. Ultimately though, i'd have thought the quickest way to gain HP would be to drop the 750 head and pistons in..?
