400/600 build questions.
Posted: Tue May 22, 2012 11:44 pm
I'm in the middle of a 600 swap and figured that i should ask a few questions rather than reinventing the wheel. I got the motor bolted in and just have to resolve a few issues.
1) Does anyone have a pic of where to relocate the coils?
2) What header clears the front fairing? I would prefer to use an EXUP one if there is one that fits.
3) I'm using a 400 radiator and the fan does not fit. Will it be ok for street riding that way as long as I stay out of stop and go traffic?
4) My 600 carbs are currently damaged, will it work with the 400 carbs?
5) Will a stock 400 or 600 air box work or do i need pods?
6) Should I remove the plastic vents that are located behind the mid fairings and the plastic cover that blocks off the carbs, air box, and coils from radiator heat? They are touching the taller 600 motor and i think they might melt.
7) Do I need the 600 fuel pump?
