hagon shocks
FZR400 Forum
13en
hagon shocks
Post by 13en »
hi ive got a F reg FZR 400 1en which im building into a road legal track bike with R6 fairings, R6 levers, R6 brakes pics to follow very soon.
But what im after is changing my rear shock and front fork springs to hagon mono shock and hagon fork springs. im wondering if any has had any experience with them and are they any good or could you recommend any other brands with are good.
many thanks :thumbsup:
zero9243
Level 8.5
Level 8.5
Re: hagon shocks
Post by zero9243 »
13en wrote:hi ive got a F reg FZR 400 1en which im building into a road legal track bike with R6 fairings, R6 levers, R6 brakes pics to follow very soon.
Wish I could help but I've not heard anything about them. Hopefully someone has some experience with them.
Upgrades:
taggy
Level 1.5
Level 1.5
Re: hagon shocks
Post by taggy »
ive got a set in some forks from a 3en1 track bike, (forks and bits still for sale!) you may want to up the weight of the oil as well for the track, but it's a case of try it first standard then change it to see if it works better for you. i never had any worries about the front and is was a massive improvement over the stock ones that had me lifting the rear going into the hairpin at malloy, which isn't much fun!
the rear i don't know about but it's seen as a more budget shock compared to others but i recon it would be ok. I used the standard set hard and seemed to manage ok, again it will be an improvement over stock without a doubt!
hyperpro do some aswell i think.
Fzr400 3tj x2
'94 cbr 900rr
Bike_junkie
Re: hagon shocks
Post by Bike_junkie »
I know cb160 racers swear by hagon shocks. But I dont have experience with their mono shock
cb175 cafe sitting in storage
88 fzr4/6, only the frame is stock
Re: hagon shocks
hagons gear tends to be pretty good, know a few racers with their monoshocks but not on FZR's mostly Gixxers.
They will make the rear shock to suit you from a"kit" of bits basically.
As for front shocks take a look at my write up :-
http://www.saltmine.org.uk/fzr/fork.html
before you spend money on anything.
Best 150 odd quid i ever spent on a bike mod (and i have 50 years of riding behind me )
xtzer
Re: hagon shocks
Post by xtzer »
Yeah, I'd be interested to see pics of your bodywork conversion as well as a description of what was necessary to make it work. Are you using and R6 tank cover?
