fork seals 3en2
Posted: Wed May 18, 2011 8:59 am
by terrors
i purchased new fork seals for my 1992 fzr400 3en2 with the dimensions below but they seem really difficult to get in and they are a wee bit bigger(2mm approx) than the old seal.
43mm x 55mm x 10.5mm
does any one know if the dimensions are correct for my year and model
thanks in advance
jamie
Re: fork seals 3en2
Posted: Thu May 19, 2011 3:21 am
by taggy
i think the 3tj rr ones are 43 mm x 10.5, the 3en2 are 41mm i/d I believe. double check by measuring the diameter of your fork top!
Re: fork seals 3en2
Posted: Thu May 19, 2011 1:52 pm
by terrors
thanks taggy for the reply have ordered the correct set
thanks jamie
Re: fork seals 3en2
Posted: Thu May 19, 2011 3:47 pm
terrors wrote:thanks taggy for the reply have ordered the correct set
thanks jamie
Jamie,
seeing as how you have an FC badge for an avatar and you have a 3en2 bike you are a fellow Brit would be a good idea if you put your location in your personal profile.
The Americans never had that model so you will have to rely on the British Chapter help you out .
Re: fork seals 3en2
Posted: Fri May 20, 2011 9:56 am
by dru86
taggy wrote:i think the 3tj rr ones are 43 mm x 10.5, the 3en2 are 41mm i/d I believe. double check by measuring the diameter of your fork top!
That is correct. The 3en2 also uses the same seals as the UK 93-96 fzr600, which is know as the yzf600 in the US.
Re: fork seals 3en2
Posted: Sat May 21, 2011 7:09 am
by terrors
thanks for the help guys
Re: fork seals 3en2
Posted: Wed Jun 08, 2011 8:40 pm
by MonsterBike
Really make a difference to know the standards used. A little difference and it won't fit.
