i purchased new fork seals for my 1992 fzr400 3en2 with the dimensions below but they seem really difficult to get in and they are a wee bit bigger(2mm approx) than the old seal.
43mm x 55mm x 10.5mm
does any one know if the dimensions are correct for my year and model
thanks in advance
jamie
fork seals 3en2
Re: fork seals 3en2
i think the 3tj rr ones are 43 mm x 10.5, the 3en2 are 41mm i/d I believe. double check by measuring the diameter of your fork top!
Fzr400 3tj x2
'94 cbr 900rr
'94 cbr 900rr
Re: fork seals 3en2
thanks taggy for the reply have ordered the correct set
thanks jamie
thanks jamie
Re: fork seals 3en2
Jamie,terrors wrote:thanks taggy for the reply have ordered the correct set
thanks jamie
seeing as how you have an FC badge for an avatar and you have a 3en2 bike you are a fellow Brit would be a good idea if you put your location in your personal profile.
The Americans never had that model so you will have to rely on the British Chapter help you out .
Re: fork seals 3en2
.taggy wrote:i think the 3tj rr ones are 43 mm x 10.5, the 3en2 are 41mm i/d I believe. double check by measuring the diameter of your fork top!
That is correct. The 3en2 also uses the same seals as the UK 93-96 fzr600, which is know as the yzf600 in the US.
Re: fork seals 3en2
thanks for the help guys
MonsterBike
Re: fork seals 3en2
Really make a difference to know the standards used. A little difference and it won't fit.
