generator cover
generator cover
hi does anyone know if a fzr600 generator cover will fit a fzr400?
Re: generator cover
Should do.
Re: generator cover
Depends on the year of the 400. Some mount the stator on the crankcase under the rotor, some mount the stator in the cover itself. The styles don't mix & match.
Re: generator cover
I'm pretty sure you can use a fzr600 cover on a fzr400 as the 400 stator is not attached to the cover, however you can't use a fzr400 cover on a fzr600. This applies to the non 3tj models of fzr400, the 3tj ones you may be able to use on a 600.
