hi guys,
i was wondering if some one could tell me how i could tell if my stator is broken or not? and a way to fix it?
need help again
- shredex
Re: need help again
Charging issues?my_negro wrote:hi guys,
- kilika2
- 1000+ Posts
Re: need help again
Yeah, any kind of breif explanation of what is going on?
I'll start you here though.
http://fzronline.com/wiki/doku.php?id=v ... flow_chart
Chris.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
Re: need help again
sorry was freeaking out. charging issues. battery drains doesnt seem to want to charge. any suggestions?
- shredex
Re: need help again
could be bad connection of wires.my_negro wrote:sorry was freeaking out. charging issues. battery drains doesnt seem to want to charge. any suggestions?
make sure your battery has full connection. run over the harness looking for frayed wires or corroded connectors.
Re: need help again
check your voltage regulator as well.. That's a problem that's prone to happening quite frequently and could very will be your culprit
89 FZR 400
Custom Paintjob
600 plastics.
06 - R6 Shock
FZR600 Motor
Soon to be:
Broke........
Custom Paintjob
600 plastics.
06 - R6 Shock
FZR600 Motor
Soon to be:
Broke........
- shredex
Re: need help again
Yea, this was my problem when I had charging issues...Except it was a bad connection to the VR.bweight wrote:check your voltage regulator as well.. That's a problem that's prone to happening quite frequently and could very will be your culprit
My connectors were green from corrosion.
If you have an old style VR then nows a good time to upgrade to an yzf600, R6, R1, pretty much any later model yamaha VR should work.
