The calipers need to be overhauled with new seals but they are expensive at about £40 at £5 per piston.
The r6 blue spot caliper upgrade at this stage might be worth doing.
I know this have been covered in other threads but I'm struggling to find a definitive answer to the following:
The upper fork cartridges on my bike are the 38mm diameter type. The distance between centres on the caliper mounting points on the fork lowers are 100mm and I have found a set of r6 calipers with the same.
This means they should fit the mounting points. Can someone confirm it is just that simple?
I'm concerned that I will have to start messing around with disk offsets etc Are the calipers *LITERALLY* a direct bolt on replacement?
Here is a picture of my right fork and disk in the hope that this helps someone answer my question asap please.
Thanks
I have posted this in the fzrarchives too. Apologies for the duplicate.
