New member UK - FZR 400 3en1
Posted: Tue Mar 30, 2010 11:02 am
Hi all,
Bought my FZR 400 3en1at the end of last year with an intention to run her on the track this year. I'll be doing a more in depth restoration next winter.
She's a little bit beaten up but I've made some good progress since the following pics.
Done so far:
Rear subframe removed and restored
New Chain / sprockets
Air filter
Spark plugs
Oil and filter
Fuel delivery system restored
New Dunlop Alpha-10
Modified Clip-ons
Stainless brake lines
The majority of accessible bolts undone, cleaned, copper greased and replaced with stainless where possible
Cooling system dismantled, checked and refilld with 60/40 ethylene glycol coolant (I have a fan question in technical thread)
Forks rebuilt New seals and fresh 15 weight oil
To do:
R6 Rear shock conversion
Fairings
Front wiring loom to sort and fit clocks.
Engine seems fine. *Possible* head gasket issue and carbs need a clean / tune (might as well do a valve clearance then)
Clean it
Ride it
Fix whatever I buggered up above
Yes, there will be questions
Done so far:
Air filter
Spark plugs
Oil and filter
New Dunlop Alpha-10
Modified Clip-ons
To do:
Fairings
Clean it
Ride it
