I thought I'd post here on the 400 page in addition to the want ads, since that's mostly 600 stuff. I need a set of undrilled 400 damper rods. Or if you have a set of bent 400 forks lying around, I'd be interested in grabbing those for the dampers. Please PM me if you have some.
Thanks!
Anyone have a set of bent forks or damper rods?
Re: Anyone have a set of bent forks or damper rods?
I may have a set.
A,apex wrote:I thought I'd post here on the 400 page in addition to the want ads, since that's mostly 600 stuff. I need a set of undrilled 400 damper rods. Or if you have a set of bent 400 forks lying around, I'd be interested in grabbing those for the dampers. Please PM me if you have some.Thanks!
if you cannot find un-drilled then weld the holes closed and put new ones in at stock height but 90 degrees round (will not effect the workings. Just de-burr and radius the new holes.)
