Hey everyone,
So couple days ago there was a storm, very windy and lots of rain. My bike was parked outside but was covered the entire time. When it finally got warm again, I started up the bike with no problems but noticed that when I revved the bike, the needle wouldn't go higher than 2k rpm but the engine is clearly revving at 4k+. I can see the needle is trying to go higher but seems like it can't. Anyone have this problem before? Thanks.
Tachometer needle stuck at 2k RPM
dyeung0415
remegio731
Re: Tachometer needle stuck at 2k RPM
havent encountered such problem before, but try to check the wiring that lines up to tacho for corrosion. or just check for any sediments causing blockade to the needle.
Open it up and check the back end of it (behind the face) I had a small plastic piece broken off inside and it wedged into the mechanical part of the tach
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
R3TARD wrote:Open it up and check the back end of it (behind the face) I had a small plastic piece broken off inside and it wedged into the mechanical part of the tach
DYE,
if you think it was due to rain you should check you electrics, how ever R3tard has avalid point that it may just be coincidence as I have had 3 mal-functions on speedo's/ tacho's over the years that were physical jams as he has described.& only one due to electrics.
