Hello from a new fzr lover
Posted: Wed Apr 29, 2009 7:56 am
by buzzawak
Hi All,
I have recently got off Ebay a 1988-1wg/1989-3EN2 in a sad condition which I will be fixing up as money and time allows. Well the engine and frame is 88 and all the rest seems to be bolted on from a 3en2.
I am in Australia and its a Japanese import. I was hoping some of you more knowledgeable owners could shed some light on a few issues I am having.
1) I have managed to download a number of manuals for some of the Fzr flavors but cant find a 1WG manual.
Would anyone have a copy available?
2) The many manuals I have read describe the same procedure to set the float level on the fuel bowl of the carburetors. Which is measuring a specific distance down for the "float Chamber line"
My problem is I do not have a "Float chamber line" marked on the base of me carburetorsImage
I think that's it for the moment.
Thank you for reading my post
Michael
Re: Hello from a new fzr lover
Posted: Wed Apr 29, 2009 8:34 am
by tkclow
Welcome aboard :cheers:
Posted: Wed Apr 29, 2009 8:54 am
by Dragon
Welcome!
Someone should be able to help you out.
Check the WIKI, and see if your question isn't answered there. :headbang:
Pics of your bike would be awesome too!!
:yutugh2:
Posted: Wed Apr 29, 2009 9:15 am
buzzawak wrote:Hi All,
Michael
Michael,
Welcome aboard, there are few members in Oz & NZ so you need to add your location in your profile saves someone telling you about a great shop in Pasadena.
The setting up of FZR carbs is not like other Mikuni's & yes our WIKI is the place to look for tech stuff for sure (not only FZR but general engineering to do with modifying bikes.)
Things to do with any bike you just bought:-
Change all Fluids
clean & inspect spark plugs (our are down a deep hole so you need to blow out the crap in that hole BEFORE removing plugs )
Check you Voltage regulator (under LH seat panel (when seated on bike)
If it is a tin can full of rubber remove it and addd anew version heavy finned type (R1 R6) as the originals tend to burn out at the drop of a hat and take out the wiring loom & TDI (black box ignition, our bikes DO NOT have CDI's)
Check swing arm, wheel bearings , steering bearings, tyres & Brakes
That should keep you busy for an hour or two :-}
Posted: Wed Apr 29, 2009 6:08 pm
by buzzawak
Tkclow
Dragon
Yamaha George
Thank you for the welcome
I have read most of the wiki ( cant find the info about the carbies there)
George thank for the advice, I have covered most of the stuff you mentioned.
Thanks again
Posted: Wed Apr 29, 2009 6:30 pm
buzzawak wrote:Hi,
Tkclow
Dragon
Yamaha George
Thanks again
B,
it is under the how-to's on the tech book & links page (you will find all sorts of goodies there , I know I put adlot of them there LoL)
http://fzronline.com/wiki/doku.php?id=carburetor_page
Posted: Wed Apr 29, 2009 9:25 pm
by buzzawak
Hi George,
Sorry but I cant find the information I'am after. I have looked at all the how to stuff.
I am looking for info on how to set the float level when you dont have a "float Chamber mark"
on your carbies.
Posted: Wed Apr 29, 2009 9:28 pm
by 95FZR600
Welcome! Be sure to check out the Chat area. :thumbsup:
Posted: Wed Apr 29, 2009 9:58 pm
by Dragon
buzzawak wrote:Hi George,
on your carbies.
I think you have to measure from the highest point on the floats to the base of the carb. Don't think there's a mark on the float chambers for measuring the heights. Hopes this helps! Good luck!
Posted: Thu Apr 30, 2009 12:30 am
by buzzawak
Dragon wrote: I think you have to measure from the highest point on the floats to the base of the carb. Don't think there's a mark on the float chambers for measuring the heights. Hopes this helps! Good luck!
Hi Dragon, The picture shows the procrdure listed in all the FZR manuals. As you can see I dont not have the "Float level mark" on my carbies.
Posted: Thu Apr 30, 2009 2:05 pm
by Dragon
Sorry, I have never used this method of setting my float heights. You probably have a different type of carbs, than what's on my fizz. Someone else may be able to help with this..... IDK
