Anyone knows for sure if cylinders and pistons of the 3BF (1WG) can be cleaned with Ultrasound an citric acid (ultrasound cleaner).
Is there any coating that can take harm?
Thanks
Mouser
ultrasound on cylinder
Evilchicken0
- Level 3.5
Re: ultrasound on cylinder
Don't think they're coated - you mean engine pistons ?
FZR400RR 3TJ Bimota SB6
Thanks for the answer, yes I mean the engine pistons.
Evilchicken0
- Level 3.5
I used a wire brush on a drill to do the crowns of mine. If you think the oilways are blocked then I'd probably just leave them in petrol for a while.
